USRP Software Radio
USRP configuration utility unusable
A directly connected cable should work fine. You must have one gigabit ethernet anything slower will not work with your USRP.
Message 31 of 33
(3,045 Views)
The USRP is detected using the NI driver. But when I go back the laptop with the UHD I downloaded to be able to use GNU radio, it says no device detected. I really need help here on how to connect to teh USRP device using UHD. or is it possible to use GNU radio with NI Driver??
Message 32 of 33
(3,038 Views)
Hello Yasmine,
It may be best to start a new thread for your particular issue.
Have you looked at this post? -> GNU radio versus LabVIEW
Ensure you are using UHD 3.4.4 and check the IP address settings on your laptop.
Anthony F.
Staff Software Engineer
Message 33 of 33
(3,032 Views)
