USRP Software Radio
USRP configuration utility unusable
Hey HB-EUM,
I've been talking with our software team and I think I may have a work around for you to get your FW and FPGA image updated.  It's possible that your FW and FPGA image are older versions that the configuration utility is compatable with.  UHD is able to recognize them, but if they are older that the version of UHD being used it can still cause issues.  Using the usrp_n2xx_net_burner utility should allow you to specify the IP address of the device like you did to change the IP address.  I attached the net burner in case you don't have it.  In order to be able to post it to the forums, I changed the file extention to .txt.  After downloading the file, change the file extentions to .py to use it.
From the command line, you can update your FW and FPGA image using the following commands:
usrp_n2xx_net_burner.py --addr=192.168.10.3 --dont-check-rev --fpga=C:\Program Files\National Instruments\NI-USRP\images\usrp_n210_r4_fpga.bin
usrp_n2xx_net_burner.py --addr=192.168.10.3 --dont-check-rev --fw=C:\Program Files\National Instruments\NI-USRP\images\usrp_n210_fw.bin
Those are the file paths for where my NI images are located, it may be slightly different on your computer.  We will work on adding better error descriptions in the configuration utility for the a future release.
Sarah Yost
Senior Product Marketing Manager
Message 11 of 33
(4,300 Views)
Hallo,
thanks for the suggestion. I did copy it and changed the .txt with .py in the name of the document. But when I'm trying to call the program by writing the command usrp_n2xx_net_burner_py, I get the error message: "Windows cannot open this file:.."
What am I missing?
best regards
HB-EUM
Message 12 of 33
(4,290 Views)
Hi HB-EUM,
The forums aren't letting me post the file that I need to post.  Please go to this link to download UHD:
http://ettus-apps.sourcerepo.com/redmine/ettus/projects/uhd/wiki/UHD_Windows
It is a small download and a quick install.  I would recommend downloading version 003.004.001, 32 bit.  Once it installs, you will have all of the utilities you need.  For me, they are located at this file path:
C:\Program Files (x86)\UHD\share\uhd\utils
Then from that file you can use the commands in a command prompt from my last post to update your FW and FPGA image.
Sarah Yost
Message 13 of 33
(4,288 Views)
Hi Sarah,
there are days, one feels completely stupid, like myself now.
I installed the UHD, no problem. I found the .py files. But I still have the answer: windows cannot open this file". When I'm typing the command line in a cdm.exe window.
I guess, it doesn't know what to do with the python file.
Any idea?
HB-EUM
Message 14 of 33
(4,285 Views)
I'm pretty sure you will need a python intrepter for windows if the UHD install doesn't come with one.
Anthony F.
Staff Software Engineer
Message 15 of 33
(4,280 Views)
Hy Anthony,
You are right. I installed the python interpreter and it looks good.
I'm now going to write the commands suggested by Sarah.
best regards
HB-EUM
Message 16 of 33
(4,270 Views)
Hi Sarah,
I tried to write the line command you described but I get an error during the execution. Are all the parameters correct:
I joined as attachment the window showing the results.
Thanks for your comments
HB-EUM
Message 17 of 33
(4,263 Views)
Try this:
usrp_n2xx_net_burner.py --addr="192.168.10.2" --dont-check-rev --fpga="C:\Program Files\National Instruments\NI-USRP\images\usrp_n210_r4_fpga.bin"
Sarah Yost
Message 18 of 33
(4,259 Views)
Mmmm
In my message, I mistyped the IP address, it was actually 192.168.10.2 as it can be seen in the "print screen" in the attachment.
Otherwise, I don't any difference between what I actually typed and what you are now suggesting. Do I?
HB-EUM
Message 19 of 33
(4,255 Views)
In my post above I added quotes around the IP address and the file path to the images.  The IP address can be whatever you need it to be for your devices.
Sarah Yost
Message 20 of 33
(4,253 Views)
