USRP Software Radio
USRP-b210 connection problem
Hi. I am trying to connect and use an Ettus USRP b210 instrument in LabVIEW NXG 2.0.
However, unlike the existing NI USRP-2922 device, the b210 device does not appear in the NI USRP Configuration utility file.
Likewise, if the 2922 device is connected via Ethernet, the connected ip address is displayed in the NXG software panel, but the b210 device is not detected.
What should I do to use the b210 device in LabVIEW?
(2,875 Views)
Have you tried using normal LabVIEW? I don't know if ettus devices are currently supported in NXG.
(2,757 Views)
