Hi. I am trying to connect and use an Ettus USRP b210 instrument in LabVIEW NXG 2.0.
However, unlike the existing NI USRP-2922 device, the b210 device does not appear in the NI USRP Configuration utility file.
Likewise, if the 2922 device is connected via Ethernet, the connected ip address is displayed in the NXG software panel, but the b210 device is not detected.
What should I do to use the b210 device in LabVIEW?
在 08-23-2019 03:13 PM
Have you tried using normal LabVIEW? I don't know if ettus devices are currently supported in NXG.
