USRP Software Radio
TV reception on USRP
I have updated to UHD. Does this have to do anything with the fact that I am unable to execute the tv_rcv example ? It says 'cannot find name uhd'. I have added the path, and the other examples like fft and C_file are running. What could be the reason ?
(7,530 Views)
Hello Nitin,
I am unfamiliar with the tv_rcv example.  Where did you retrieve this example?  When you say that you updated to UHD, what changes did you make?
Currently the only supported interface to the USRP is through LabVIEW using the NI-USRP driver, but if you have more information other members on the forums may be able to help.
Anthony F.
Staff Software Engineer
(7,522 Views)
Hello Nitin -
It sounds like you may be using UHD with the USRP.  The UHD driver is open source is message board supported by mailing lists:
Sign up here for the GNU Radio mailing list to receive information on updates, current topics, code sharing and more.
https://lists.gnu.org/mailman/listinfo/discuss-gnuradio
Join other USRP users for updates on timely USRP topics and support.
http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
If you are using the NI-USRP driver in LabVIEW with Windows, you've found the right place.  Please let us know how we can assist you in this regard.
Best Regards,
Erik
(7,520 Views)
Hi Erik,
Let me check out the aspects you have touched and I'll get back to you after that.
Nitin
(7,514 Views)
