USRP Software Radio
Implementing B210 GPIO ATR for both channels
I am planning to use the GPIO ATR on a B210 as a PTT signal. Both channels will be used on the B210.
Currently, GPIO ATR can't be switched from channel A to channel B on the B210 due to the function not being implemented in UHD, from EttusResearch/uhd/host/lib/usrp/multi_usrp.cpp
void set_gpio_src(
const std::string&, const std::vector<std::string>&, const size_t) override
throw uhd::not_implemented_error(
"set_gpio_src() not implemented for this motherboard!");
Could this functionality be implemented with a script that directly accesses the ATR or tx/rx status registers? Or would I need to build custom firmware and modify the UHD drivers? Are there any good resources or tutorials for how to do either of these things?
Message 1 of 1
(1,316 Views)
