USRP Software Radio
GPS Direct Streaming Generation VI to a file
I am using the GPS Direct Streaming generation VI.  How do I save the output to a file and run the file at a later time?
https://decibel.ni.com/content/docs/DOC-22178
(5,122 Views)
Hello Donald,
To save the signal instead of immediately transmitting it with the USRP, you would not need the producer/consumer architecture from this example.  Where the producer loop Enqueues the data, you would instead save the data to a file.  You would then be able to transmit the data at a later time.
Jon F.
Technical Support Engineer
(5,100 Views)
