USRP Software Radio
Connect PC to several USRP via NI PCIe-8371
Hello all,
I have a NI PCIe-8371 installed on the Host PC's motherboard. It just has one port and one can just connect one USRP to it.
I was wondering how we can connect two USRP-2943R (120MHz) to just one PC using MXIe x4 Cable connection?
Thanks.
(4,579 Views)
Accepted by topic author Amir2
Hi Amir2,
The easy answer is to connect to one USRP with the MXI connection and the other with Ethernet. Be aware that the ethernet connection will have some limitations, including access to the FPGA. This is described in more detail in the 2943R Getting Started Guide.
If you need to be able to access the FPGA on both USRPs, there isn't going to be a way to do this without some modification of your hardware list. One option would be with the NI PCIe-8372 card instead, as it has 2 x4 MXI ports on a single card. Alternatively if your computer has two PCIe slots, you could get a second PCIe-8371.
Hope this helps!
Ashley G.
Principal Applications Engineer | RF & Wireless Communications
(4,539 Views)
 Thank you for your reply.
My computer just has one x4 slot. I use this slot for connecting one of the USRPs to Host PC via the PCIe-8371. However, my computer also has an extra x16 slot. Can I use this slot to insert another PCIe-8371?
Thank you.
(4,533 Views)
I recommend using the CPS-8910. This will allow you to connect multiple USRP RIOs using the PCIe connection.
(4,528 Views)
The x16 slot will work just fine for another PCIe-8371.
- Robert
(4,525 Views)
Thank you Robert.
(4,520 Views)
