USRP Software Radio
취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
Can 4Rx simultaneously function in X310
Hi, in the exhibition of MILCOM 2016, I stopped by the booth of NI. They demo a DOA estimation with 4 antenna using X310. But checking the data sheet of X310, I found that X310 only has two RF chains, so how the DOA demo use 4 antenna based on one X310? Thanks,
0 포인트
1/6 메시지
4,377 조회수
The X310 is a motherboard, which has two slots for daughterboards. The demo uses two TwinRX daughterboards, which each have two RX channels.
0 포인트
2/6 메시지
4,355 조회수
Gotcha. Thank you for your information. BTW, what are the development tools for the X310 and Two TwinRx? Labview only or also good for GNURadio?
0 포인트
3/6 메시지
4,349 조회수
No problem! There are several development toolflows for the X310 plus TwinRX. You can use GNURadio and The Mathworks MATLAB & Simulink to program the device now.  NI-branded HW (the USRP 2945 and 2955) will arive in mid-January and support LabVIEW and LabVIEW FPGA. The NI-branded HW will also have CE/UL certification and NI support.
0 포인트
4/6 메시지
4,332 조회수
Hello, USRP X310 changes 2 RX channels into 4 input RX channels. What changes need to be made to the underlying VERILOG program?
0 포인트
5/6 메시지
3,545 조회수
Hi naniandechunyang,
Could you be a little more specific regarding what Verilog program you are referring to?
0 포인트
6/6 메시지
3,518 조회수
