USRP Software Radio
B200 mini input power full scale
The spec of B200 is maximum input power -15dbm.
However my measurements show that at 2GHz, sine input, at +10 dbm , gain 0, the sinewave amplitude is ~13400 and the maximum is 32768.
Can someone enlighten me how it is possible?
Sorin
(936 Views)
I've always suspected that the max power level input of -15 dBm is a safe limit for the hardware, but not for the analog to digital converter. I am working on received power calibration and wonder if this calibration will give the correct full scale behavior.
(797 Views)
The -15 dBm is the most vague value and super relative to interpret in my opinion.
In terms of the USRP, we do not know:
- How is this measured?
- What is the signal that was put into it to test?
- What is the frequency?
- What is the gain set?
- Is this an average value measured over the full bandwidth?
This is not documented as far as I am aware.
However, generally I believe caution needs to be taken, if you know that the AD9361/9364 RFIC has a max. peak input level of 2.5 dBm (again no frequency/signal info).
So:
- Do you transmit a calibrated signal?
- Is your signal an RMS signal, what is the amplitude?
- What is your applied FFT window when visualising?
- How is your incoming signal connected to the B200 (wired/wireless)?
Also note that the B200 is not calibrated by default. What you measure is not necessarily the true value.
The -15 dBm (at 0 dB gain) is I believe a safe value to not damage your hardware as @keukenrol said, and to not clip your ADC in the end.
(518 Views)
