USRP Software Radio
NVIDIA mellanox 5 alternative
I am attempting to build a setup to operate USRP x410 radios. The recommended cards (see below) do not seem available anymore and NVIDIA has in fact removed them from the web.
Recommended 100 Gigabit Ethernet Cards
  • Mellanox/NVIDIA ConnectX-5 EX 100 GbE NIC (MCX516A-CCAT (PCIe Gen3 x16))
  • Mellanox/NVIDIA ConnectX-5 EX 100 GbE NIC (MCX516A-CDAT (PCIe Gen4 x16))
The replacements seem to be ConnectX-6 Lx 25/50G NIC (with QSFP28 ports but only supporting up to 50gb/s) or ConnectX-6 Dx 25/50/100/200G NIC with QSFP56 ports.
Is there a new recommended card? Would the QSFP56 card from NVIDIA be compatible? In that case what would be the recommended adapter cable/layout?
(248 Views)
the Nvidia ConnectX-6 Dx with QSFP56 ports should work as alternative to the older ConnectX-5 EX cards, since QSFP56 is designed to be electrically backward compatible to QSFP28 and both use mechanically the same connector (so also https://en.wikipedia.org/wiki/Small_Form-factor_Pluggable). The core advantage of QSFP56 is that it supports higher maximum line speeds.
(242 Views)
