UI Interest Group Documents
ni.com Inspired Custom Control Suite
Preview Image:
Installation Instructions (manual):
Unzip the attached ni.com theme.zip file in your <LabVIEW Install Directory>\menus\Controls\ folder and then restart LabVIEW to add all the above controls to your palette.
Installation Instructions (automated):
Download the attached ni_lib_ni.com_inspired_controls-1.1.0-1.vip VI Package file and install using VI Package Manager™ (VIPM). VI Package Manager is an installer for LabVIEW VIs and toolkits. It places VIs directly into the palettes, allows you to install VIs into multiple LabVIEW versions, and ensures that any dependency VIs and toolkits (provided in other VI packages) are also installed. VI Package Manager is a trademark and product of JKI Software.
Source Files (optional):
All of the source images used when creating the custom controls are included in the ni.com theme.zip file as Adobe Fireworks PNG files.  If you have Adobe Fireworks you can open them up in their original vector for
Comments
Jim_Kring
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
I created and attached a VI Package (ni_lib_ni.com_inspired_controls-1.0.0-1.vip file above) of these controls that can be installed using VI Package Manager.
hex
on
Very-very nice pack, thank you very much!
spsuamin
on
Definetly sweet looking interface.
Russ_Evans
on
Really nice looking set of controls. Thanks for sharing.
Elijah_K
on
If you like these, just wait, he has more!
Elijah Kerry
NI Director, Software Community
NevD
on
These are great, and thanks to Jim for the VIPM package.  Looking forward to a tab, multicolumn listbox, table, filepath, cluster, array.. the whole set!!
SimonH
NI Employee (retired)
on
Hey NevD, the file path control should already be in there (I think I just called it "Path").  As for the other types of controls I hadn't started on those I only did what I saw as the most popular ones.  At first glance clusters, tables and multicolumn listboxes look easy enough, perhaps even with the existing images.  Tab controls look tough as they don't have any replacable images.
SimonH
on
OK everyone, I've updated the zip file with a few new controls (namely the ones NevD asked for except the tab control).  I've also added a zip file of images that make for good panel backgrounds. Have fun and feel free to post screenshots of the controls in action!
Jim_Kring
Trusted Enthusiast
on
Cool!  I've created a new version (1.1.0) of the VI Package file, ni_lib_ni.com_inspired_controls-1.1.0-1.vip, with your new additions.
NevD
on
Thanks Simon and Jim!  That was very quick!
Aum
on
Hi Simon,
It looks cool! do you have it for labview 8.5 version?
hex
on
To Aum:
I think you can use it directly to LabVIEW 8.5, just extract the file "ni.com theme.zip" to your LabVIEW 8.5\menus\Controls\
Aum
on
No I could not use it. it says: LabVIEW load error code 9: version 8.6 is newer than...
hex
on
I already attach the files, try it...
Aum
on
thanks but where is the link???
hex
on
Check the download section above, the title is "NI Theme for 8.5l.zip". I hope it works..
Aum
on
done
LVCoder
on
Hi SimonH,
thanks alot for such a wonderful and creative work.
However, i went through a page on NI's Website and found 2 really cool UIs developed in LV.
Here's the link
http://decibel.ni.com/content/groups/large-labview-application-development/blog/2009/03/23/professional-user-interfaces-in-labview
You have already posted the controls seen the in the 1st UI on the above page.
I was wondering if you could post the controls used in the 2nd UI. The controls on the Right look extremely beautiful.
SimonH
on
Unfortunately I can't post the controls from the 2nd UI as I didn't create them - that UI was developed by one of our customers for their application.  However, if it's the numeric control you were interested in I did throw together a similar looking control and posted it over here: http://decibel.ni.com/content/docs/DOC-4614.  Again, I have included the source images (this time I created them with Powerpoint) so you can modify, customize and create additional controls.
HarrisJunaid
on
Hello Simon very nice control but please find some time to create a step wise short demo for creating custom gauge from scratch especially needle color and gauge color range thanks nice work
Joji
on
Very Cool Controls. Wish there was even more of these sets of controls around.
One issue I noticed with the controls.  If you were to replace an existing control with one of these controls using the Right-Click>>Replace.. method, then it will replace numerics with a listbox even when you choose to replace with numerics. The buttons and graph/charts seem  to work though.
Joji
vix
on
Could someone make this theme available for LabVIEW 8.2.1?
Sorry, but could someone help me?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
sealiker
on
I like this theme  ............ but I use Labview 7 Express so I don't get to load the controls.
Is there a way for me to load the theme in Lavbview 7?
rex1030
on
Is there any possible way that array and cluster controls could be added to this pack?
edit: Looks like its just a link mixup. The link at the bottom under downloads is the right one.
I am definately getting some strange behavior with the different controls when i click on an existing control and try to right mouse click > replace the control with the new sweet looking ni.com themed controls. Replacing buttons and numeric controls are fine. Replacing error controls or arrays on the other hand do some wierd stuff. Any thoughts?
[will work for kudos]
SimonH
on
@rex1030 They should already be in there.  Which version did you download (I added them around March 25th)?
KrisnaWisnu
on
This is very nice,, thanks for sharing!
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2021
muks
Proven Zealot
Proven Zealot
on
Really nice ones. Nice thought
scottcolston
on
These look great. Do you have an XY graph control? Thanks
Ashish_Naik_NIUK
on
This does look great!
Ashish Naik
Automotive Business Development Manager
National Instruments UK
Al-Zahrani
on
Thank you for that, very nice
KleeD
on
looks awesome and should be a good starting point for further customizations. Thank you very much.
catkin
on
hi,i am  a  newer,     how  I  use it,and  where  I place it?
catkin
on
hi, I am a newer, would you like to tell me  how can I use it?
thanks !
Knight of NI Knight of NI
Knight of NI
on
Hi catkin,
did you read the two blocks on "Installation instructions"? Really?
Boone301
on
More and more exciting!
Srikanth@Siri
on
Hi nice work...They are very good controls....but can you add the boolean controls...
Srikanth Kandagatla
GRamy
on
Nice One SimonH, Good Work
MikeC3
on
Anyone else notice odd behavior with the table control?  If I use it as an indicator and write a changing array of strings to it, it will keep displaying the old strings in addition to the new strings, and thus becomes unreadable.  The multicolumn listbox works ok, so seems to be something just with table.
RyanCheng
on
Looks very nice!
But I still want to know how to make controls more beautiful.
cl13776506687
on
it's very nice!
A.Salcedo
on
hi! First of all thanks a lot for doing this! it is awesome.
I am trying to change the color OFF button but I can not do that in properties. Is there any way to do that?
Thanks a lot.
Christina_R
on
If you want to change the color of the button in this set, you would need to edit the PNG images for the button states (with an image editor program) and then import the modified iimages into the button (using the Customize mode of the Control Editor).
Christina Rogers
Principal Product Owner, LabVIEW R&D
cl13776506687
on
hi,i'm glad to here from you,last month i joined the NI community and found a lot of resources ,you can search the key word and look for some demos,i have found some video from www.mufenglv.com
RyanCheng
on
Thank you for your kindly help, and in several years age, I have joined www.mufenglv.com. It's a very good to learning and upgrade the NI LabVIEW technology community.
Contributors
