UI Interest Group Documents
'Military' Theme Custom Control Suite
Installation Instructions:
Unzip the attached "military.zip" file in your <LabVIEW Install Directory>\menus\Controls\ folder and then restart LabVIEW to add all the above controls (and more) to your palette.  Note:  these controls were made in LabVIEW 2009.
** Added 8.2 Controls. Could not go back further to saving under LV7.x.
Comments
Member sealiker
Member
Hi, SimonH. Thanks for sharing these cool customized controls. I want to try these controls badly, but I only have Labview 7 Express. Is there any way I can make the controls usable with Labview 7?
SimonH
NI Employee
All of the source images I used are in the zip file -- you could customize the controls yourself using the control editor (this would probably take a couple of hours though).
The other option is for someone with the appropriate versions of LabVIEW to back save the controls to LabVIEW 7.  My laptop is short on hard-drive space these days so I only keep the latest version installed.
Can anyone help out?
Rick K
NI Employee
Beautiful.....
Member normandinf
Member
I've added 8.2 controls, but it cannot be saved back to LabVIEW 7. I think the only way will be to recreate them as mentioned by SimonH.
Member origin
Member
Cool Stuff.. Thanks for sharing..
Active Participant ColeTrain
Active Participant
Hey Simon,
Great looking controls, but are you going to make a .vip for distribution instead of just the .zip?
ColeR
Field Engineer
Member CaoWJ
Member
Hi, SimonH.thank you for your sharing. I will use these in my coming projects
Member Fenix21
Member
Excelente, saludos desde Nicaragua
Member IYUS
Member
great ui, I shall look forward for your next theme
Member brijesh
Member
just beaty. Thank you so must for sharing this controls.
CLAD
Labiew programmer
Member undermeadow
Member
There is an error in the Table Control. When you write to the table by program the old content is not erased and the new text is mixed with it until the program is stopped.
Same error is in the Ni.com Theme.
But still it is nice theme :-)
Member NVT
Member
Thanks so much
Member andy_glass
Member
are these still available to download as I keep getting timed out????
Knight of NI
Knight of NI
Hi jobby,
it seems NI moved those files to a different server (or folder on their server) as the URL points to "decibel-test.ni.com" instead of the usual "decibel.ni.com"...
You can get the files, when you copy the URL and remove the "-test" from it!
CLAD expired, using 2009SP1 + LV2011SP1 + LV2017 (+LV2018 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
Member andy_glass
Member
many thanks for the help
Active Participant LabBEAN
Active Participant
In case GerdW's comment got cut off in your email (like it did for me) here are the links to download:
https://decibel.ni.com/content/servlet/JiveServlet/download/6325-2-8644/Military_v82.zip
https://decibel.ni.com/content/servlet/JiveServlet/download/6325-2-8633/Military.zip
https://decibel.ni.com/content/servlet/JiveServlet/download/6325-2-8632/Military%20Source%20Images.z...
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Knight of NI
Knight of NI
Hi LabBEAN,
the links in the notification emails suffer by the same problem: their link contains that shitty "-test". Someone screwed NI's community off...
Trusted Enthusiast
Trusted Enthusiast
Hi!
I would like to try these ctrls, but my LabView 2012 crashes when I restart it. Also, if I try to open a ctril, LabView 2012 crashes...
Trusted Enthusiast
Trusted Enthusiast
I fixed it:
I made a custom folder under /Controls and I put all the ctrls there. Now LabView works
Active Participant Christina_R
Active Participant
Blokk - thanks for letting us know. I've filed Corrective Action Request 378596 to report the crash.
Christina Rogers
Product Owner, LabVIEW R&D
Active Participant Jeff-P
Active Participant
CAR 378596 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Knight of NI Knight of NI
Knight of NI
Member tuocheng
Member
So beautifui!Thanks.
Member kakasun
Member
really cool, thank you,SimonH
Member Roger_P_Case
Member
I am out of the office until 08/10/2015.
Contact me for phone or email access.
Note: This is an automated response to your message "Re: [UI Interest
Group] - 'Military' Theme Custom Control Suite" sent on 8/4/2015 3:35:45 AM
This is the only notification you will receive while this person is away.
Member Xv_qcc
Member
Thank you~
Member fyp123
Member
thanks so much
Member wtsos
Member
UI Control Suite: Metallic Theme?
Contributors
