Installation Instructions:
Unzip the attached "military.zip" file in your <LabVIEW Install Directory>\menus\Controls\ folder and then restart LabVIEW to add all the above controls (and more) to your palette. Note: these controls were made in LabVIEW 2009.
** Added 8.2 Controls. Could not go back further to saving under LV7.x.
Hi, SimonH. Thanks for sharing these cool customized controls. I want to try these controls badly, but I only have Labview 7 Express. Is there any way I can make the controls usable with Labview 7?
All of the source images I used are in the zip file -- you could customize the controls yourself using the control editor (this would probably take a couple of hours though).
The other option is for someone with the appropriate versions of LabVIEW to back save the controls to LabVIEW 7. My laptop is short on hard-drive space these days so I only keep the latest version installed.
Can anyone help out?
Beautiful.....
Cool Stuff.. Thanks for sharing..
Hey Simon,
Great looking controls, but are you going to make a .vip for distribution instead of just the .zip?
Hi, SimonH.thank you for your sharing. I will use these in my coming projects
Excelente, saludos desde Nicaragua
great ui, I shall look forward for your next theme
just beaty. Thank you so must for sharing this controls.
There is an error in the Table Control. When you write to the table by program the old content is not erased and the new text is mixed with it until the program is stopped.
Same error is in the Ni.com Theme.
But still it is nice theme 🙂
Thanks so much
are these still available to download as I keep getting timed out????
Hi jobby,
it seems NI moved those files to a different server (or folder on their server) as the URL points to "decibel-test.ni.com" instead of the usual "decibel.ni.com"...
You can get the files, when you copy the URL and remove the "-test" from it!
many thanks for the help
In case GerdW's comment got cut off in your email (like it did for me) here are the links to download:
https://decibel.ni.com/content/servlet/JiveServlet/download/6325-2-8644/Military_v82.zip
https://decibel.ni.com/content/servlet/JiveServlet/download/6325-2-8633/Military.zip
Hi!
I would like to try these ctrls, but my LabView 2012 crashes when I restart it. Also, if I try to open a ctril, LabView 2012 crashes...
I fixed it:
I made a custom folder under /Controls and I put all the ctrls there. Now LabView works
Blokk - thanks for letting us know. I've filed Corrective Action Request 378596 to report the crash.
CAR 378596 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
http://forums.ni.com/t5/LabVIEW/metallic-theme-waveform-graph/m-p/3061297#M872906
Metalic XY Graph at the above link
So beautifui!Thanks.
really cool, thank you,SimonH
I am out of the office until 08/10/2015.
Contact me for phone or email access.
Note: This is an automated response to your message "Re: [UI Interest
Group] - 'Military' Theme Custom Control Suite" sent on 8/4/2015 3:35:45 AM
This is the only notification you will receive while this person is away.
Thank you~
thanks so much
UI Control Suite: Metallic Theme?
