UI Interest Group Discussions
Rotating Images at NI Week 2009
If you watch the NI Week Web UI Keynote talk at http://www.youtube.com/watch?v=7dWrc-R23zk; at 3min8sec they mention that the wind-vanes shown are rotating images (and obviously have some transparency).... "Images we've applied a rotation animation to"
This looks VERY slick, but I can't figure out how this would be implemented.
How was this implemented? I've seen various discussions on this when googling the problem, but no good solutions.
Message 1 of 9
(10,408 Views)
Web UI Builder is implemented on Microsoft Silverlight technology.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 2 of 9
(6,675 Views)
This was done in the LabVIEW WebUI builder, which is a different product than standard LabVIEW and is not quite released yet.  However seeing as they mentioned it at NI week means it must be coming along soon :-D.
I don't think this is possible in standard LabVIEW, but maybe others on here have other ideas.
Message 3 of 9
(6,675 Views)
Darn, you beat me to it by just a few seconds...
Message 4 of 9
(6,675 Views)
LabVIEW does not currently have image rotation capabilties (although I suppose you could probably write the image transformation algorithm and render it in a picture control).
LabVIEW does, however, support image transparency. If you import images to the clipboard via the Edit menu (Import Picture to Clipboard) and browse to a file that contains transparency (e.g. a PNG with an alpha channel), the transparency information will be preserved when you paste into a VI. (Note that copying and pasting an image through the system clipboard will not preserve the transparency information in LabVIEW).
Christina Rogers
Message 5 of 9
(6,675 Views)
Dragging a PNG file onto a front panel (or block diagram) as a decoration also preserves transparency.  I find this easier than going the Edit >> Import Picture to Clipboard... route.
Message 6 of 9
(6,675 Views)
Accepted by buckidge
Placing a series of pictures in a "picture ring" and rotating through the cases can give you a similar effect.
Simply add cases to your picture ring and drag the png with a transparent background (as noted by Justin).
GCentral ChampionCLA
Message 7 of 9
(6,675 Views)
Recreating the Web UI Builder demo in LabVIEW is fairly easy.  I've posted an example with a quick write up here - http://decibel.ni.com/content/groups/ui/blog/2010/09/13/windmill-ui-example
Message 8 of 9
(6,675 Views)
Thanks for the details, Norm. I gather this is how it's done, which is what I was looking for. Unfortunately though, I don't really like the answer as it is fairly clumsy with all the work required with rotations in powerpoint.
Maybe I should write a VI to make it happen easier.
Thanks.
Message 9 of 9
(6,675 Views)
