UI Interest Group Discussions
Is there interest in a Windows CE based mobile touch screen pendant as an alternative to a fixed panel display?
We have implemented this pendant running labView applications. The large touch screen, handwheel, E stop button and circuitry are fully supported.
If there si interest, how should I get the word out to labVIEW users?
(4,254 Views)
Is this a product you already have available and if so what are the specifications (dimensions, weight, power usage/method, IO options (serial port e.g.?), ingress protection, screen resolution and size etc?
(2,934 Views)
Mads,
Yes, this is an existing product. It has been implemented in LabVIEW applications.
I have attached a power point that should answer your questions about the technical specs.
Various options are available and some additional code is supplied depending on the options selected for LabVIEW implementation.
Please let me know if you need any more information.
My company is a Master distributor for Keba in the US and can supply you with this product and the supplemental code.
I will also post on the community discussion.
Thanks for the input.
Doug Dalgliesh
President
FLEXCONTROL SOLUTIONS, LLC.
610-937-2093
d.dalgliesh@flexcontrolsolutions.com
http://www.flexcontrolsolutions.com/
(2,934 Views)
