UI Interest Group Discussions
Import the image in Led Indicator by programatically
Hi friends ,i am trying to import image in led indicator by Programtically , i tried using invoke node but it only allow to read image from led indicator not to import..pls help me
Raj
Message 1 of 8
(6,302 Views)
Could you show an example of what yuo want to achive? Do you know a way to do this manually?
I hope you ment to find a programmatically way to do this in LV and that Programtically or programatically is a software I do not know of.
Message 2 of 8
(3,978 Views)
Your question is somewhat ambiguous.  Did you mean one of the following:
  1. How can I save the image from a boolean control?
  2. How can I add an image to a boolean control?
  3. How can I replace the boolean control image with one of my choosing?
You can do 1. using invoke nodes.  2 and 3 require the control editor.
Message 3 of 8
(3,978 Views)
Hi thanks for reply....I need to know how can i add image to boolean control. i know to add by manually..but i need to know in programatically...
Its like, if i give the image path to the boolean control..it should add that image .i tried invoke nod...but its doesnt give the option to write image..only to read the image data(Get image-invoke node)
Raj
Message 4 of 8
(3,978 Views)
To my knowledge, you cannot programmatically add an image to a boolean control.  However, you can get close to the same functionality by using a picture control, importing your image there, and using mouse events on the picture control to generate your boolean data.
Message 5 of 8
(3,978 Views)
ok.... thanks
Raj
Message 6 of 8
(3,978 Views)
Don't - picture controls are your friend.  You can do a lot with picture controls.
Jim
Message 7 of 8
(3,978 Views)
This XControl might help you - http://lavag.org/topic/10585-discuss-boolean-xcontrol
___________________
Try to take over the world!
Message 8 of 8
(3,978 Views)
