UI Interest Group Discussions
After customizing lag problem
After applying customization, the program slows too much. Do you know why? I've checked my png pictures what I used. Max 18 kb.
Thanks your helping and advice
(6,788 Views)
would you happen to have a bit in-depth information, like:
  • What kind of customization did you perform?
  • What else happens in your application?
  • Can you post the code or a relevant test example showing the problem?
Thanks in advance.#
Falk
(6,775 Views)
What kind of control were you customizing (also, what palette were you using)? It would be easier to find out the reason if we could see a screenshot.
Thanks in advance,
Mariam
(6,765 Views)
I've customized everything. Graph, button, tab, numeric control. I made changes on a working vi. Although this Vi works fluently, it doesn't work fluently anymore.
I can't post the code. At first vi is working fluently. As time goes by slowing down.
Could it be related to being a 32 bit? DSC module was used. Labview have to be 32 bit for DSC module.
(6,761 Views)
Do you have any decorations in the vi? Sometimes they are affecting the vi's speed.
(6,757 Views)
I don't have any decorations
(6,746 Views)
I had similar problem.
I customized a button to be translucent.
Worked fine on Windows 7 LabVIEW 2017.
But caused a big delay on Windows 10.
George Zou
(6,737 Views)
