Troubleshooting Hardware
取消
顯示結果
搜尋替代
您的意思是:
SD card will not stay inserted in RoboRIO V2
已解決!
前往解決方案
I have the same issue as described here -- https://forums.ni.com/t5/Troubleshooting-Hardware/SD-card-won-t-stay-in-roboRIO-2/m-p/4347799#M984
The SD card won't stay in, no matter what we tried - short of glueing it in.
Took it even a step further, opened the RoboRIO and carefully opened the SD card vertical socket/slot. Found a tiny piece of wire (photo IMG_1958_pin) that seems to be responsible of activating the push/push mechanism.
That wire is sooooo small that I had to use very powerful lenses to see it.
Was unable to put it back.
Does anyone know what is the part number (Digikey, Mouser, others) so I can replace that SD card vertical socket/slot?
Found something similar on Mouser but is not identical and it is manual not push/push -- https://www.mouser.com/ProductDetail/Yamaichi-Electronics/PJS008U-3000-0?qs=nO3wRANIIvnp3f0XwG2X3A%3...
Many thanks in advance,
-- Mr. Ghercoias
Team20 - The Rocketeers
下載全部
0 積分
1 條訊息(共 3 條)
1,789 檢視
解決方案
由主題作者所接受 Mr.G-Team20
Hi, Mr. Ghercoias,
This is Matthew with NI. I sent you a private message on next steps.
0 積分
2 條訊息(共 3 條)
1,745 檢視
Hello Matthew thank you so much for your help, we received the replacement RoboRIO.
All the best to you and all youir loved ones!
0 積分
3 條訊息(共 3 條)
1,710 檢視
