Troubleshooting Hardware
SD card will not stay inserted in RoboRIO V2
I have the same issue as described here -- https://forums.ni.com/t5/Troubleshooting-Hardware/SD-card-won-t-stay-in-roboRIO-2/m-p/4347799#M984
The SD card won't stay in, no matter what we tried - short of glueing it in.
Took it even a step further, opened the RoboRIO and carefully opened the SD card vertical socket/slot. Found a tiny piece of wire (photo IMG_1958_pin) that seems to be responsible of activating the push/push mechanism.
That wire is sooooo small that I had to use very powerful lenses to see it.
Was unable to put it back.
Does anyone know what is the part number (Digikey, Mouser, others) so I can replace that SD card vertical socket/slot?
Found something similar on Mouser but is not identical and it is manual not push/push -- https://www.mouser.com/ProductDetail/Yamaichi-Electronics/PJS008U-3000-0?qs=nO3wRANIIvnp3f0XwG2X3A%3...
Many thanks in advance,
-- Mr. Ghercoias
Team20 - The Rocketeers
(1,807 Views)
Accepted by Mr.G-Team20
Hi, Mr. Ghercoias,
This is Matthew with NI. I sent you a private message on next steps.
(1,763 Views)
Hello Matthew thank you so much for your help, we received the replacement RoboRIO.
All the best to you and all youir loved ones!
(1,728 Views)
