Troubleshooting Hardware
No power LED
Applying power the Power LED never comes on, nor do any others. The same power connector attached to another RoboRio works fine. When I first received the rio, I applied power and it worked. Since then, I removed the SD Card, Imaged it, and re-inserted.
I'm assuming that inserting a bad card wouldn't prevent the power light from coming on. I did double check it's inserted properly.
(1,331 Views)
Given the SD Card, I assume you're talking about a roboRIO 2.0.
A bad card wouldn't result in no power.  Instead, you'd see a flashing STATUS light telling you there was a boot error.
You don't have PMs enabled.  Are you alright with me emailing you on the account associated with your forum profile?
(1,300 Views)
Yes, please. That would be great.
(1,297 Views)
Sent that email.  We can find the best solution there 😃
(1,290 Views)
