Troubleshooting Hardware
取消
顯示結果
搜尋替代
您的意思是:
No power LED
Applying power the Power LED never comes on, nor do any others. The same power connector attached to another RoboRio works fine. When I first received the rio, I applied power and it worked. Since then, I removed the SD Card, Imaged it, and re-inserted.
I'm assuming that inserting a bad card wouldn't prevent the power light from coming on. I did double check it's inserted properly.
0 積分
1 條訊息(共 4 條)
1,333 檢視
Given the SD Card, I assume you're talking about a roboRIO 2.0.
A bad card wouldn't result in no power.  Instead, you'd see a flashing STATUS light telling you there was a boot error.
You don't have PMs enabled.  Are you alright with me emailing you on the account associated with your forum profile?
0 積分
2 條訊息(共 4 條)
1,302 檢視
Yes, please. That would be great.
0 積分
3 條訊息(共 4 條)
1,299 檢視
Sent that email.  We can find the best solution there 😃
0 積分
4 條訊息(共 4 條)
1,292 檢視
