This document is part of the SystemLink Portal.
Setting Up a SystemLink Server (simple do-it-yourself evaluation)
Use the following instructions to set up a SystemLink Server for a simple evaluation of SystemLink.
Network Setups
- Make sure that your SystemLink Server and SystemLink Clients are on the same network.
Set Up Your Server
The following instructions are based on a setup where 1) the Server system has access to the internet, and 2) the Server system is located on-premise.
Server Machine specifications
- Refer to the Sizing a SystemLink Server for the recommended specifications (e.g. 4-core Processor or higher, 16 GB RAM minimum, 6 GB disk space minimum) for your version.
- Typically, you should use a Windows Server 2012 / 2016 R2 (64-bit) / 2019 (64-bit) OS on your SystemLink Server. However, for a simple evaluation, you can also use Windows 7 SP1 (64-bit) or higher or Windows 10 (64-bit) instead if that's easier.
Refer to the SystemLink 2020 R4 Readme for OS requirements.
Setup Instructions
- Download and install the SystemLink Server on your server machine (download link).
- Refer to the instructions in the Setting Up a SystemLink Server topic in the SystemLink manual.
- For a simple do-it-yourself evaluation, the fastest way to get started is by using the "Insecure Remote Access" configuration preset shown in the following YouTube video: [YouTube] SystemLink: Installing and Getting Started with the SystemLink Server
Caution: The "Insecure Remote Access" configuration preset (i.e. connect remote clients to the server remotely over HTTP (instead of HTTPS) which does not protect/encrypt data or passwords; login with admin account; no certificate required) allows you to get started quickly for an initial evaluation, but you must make sure you set up the SystemLink Server and Client systems on a trusted network that can only be accessed by trusted clients.
- Later when you are ready to set up your SystemLink Server more securely, you can change to more secure settings and/or refer to the Setting Up Your SystemLink Server and Clients (with IT) document.
