SystemLink Forum
how to remove user account
My SystemLink Server ( as well as NI webserver) are running under Windows 10.
I could create additional user by Adding them as Windows User (password protected).
However, when we removed certain user account from windows, these user still listed in Systemlink server User list. How to delete them?
(2,777 Views)
Accepted by ThamS
Hi Guzman2479,
It is not currently possible to delete users through the SystemLink web UI.  However, there is API access to add, modify, or delete users.  If you have only a few users to delete, I would recommend just using the Swagger UI installed on the server at <host>/niapis.  From there, first use the dropdown on the top bar to navigate to the User Service.
Then, you can find the ID of the user you'd like to delete using POST /users/query, like in this screenshot.  The query uses Dynamic Linq syntax, and the full User model is documented at the bottom of the page for reference.
The response will look something like this.  Note the example curl command actually used to query the server, if you'd like to script this in future.
Using the user ID highlighted in yellow, we can then use DELETE /users/{id} to actually delete the user:
You should see a HTTP 204 response appear below if the user is successfully deleted.
You may also want to delete any associated auth mappings through the web UI, just to follow the general security principle of least privilege.  Also be aware that if the same user is added back to the server later, any existing auth mappings may be re-associated, which may or may not be your desired result.
You can also script this process if you have many users to delete, using Perl, Python, LabVIEW or any other suitable language.  Take care that your query is carefully written and tested though, as it would be easy to accidentally delete the wrong users.
Feel free to ask any follow up questions here, or if you need more detailed assistance you can reach out through a service request.
Michael B.
Product Support Engineer
(2,720 Views)
Hi ThamS,
Please see my reply to Guzman in this thread for details on deleting SystemLink users.
Michael B.
(2,718 Views)
Thank you
(2,702 Views)
Hi @MichaelDB thank you for your reply with solution.
I've a question in this case regarding API for LabVIEW:
Would you tell me how?
I can't find any Function in LabVIEW palette to the API for managing SystemLink user account or access:
(2,697 Views)
Hi ThamS,
The SystemLink API in LabVIEW doesn't include functions for talking to the user service, but you should be able to use the standard HTTP client palette to call the API endpoints on your server.  Similar to the process in this article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VpgSAE&l=en-US
The HTTP client documentation is here: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/data-communication/protoc...
Michael B.
(2,687 Views)
