SystemLink Forum
Tag data error when communicate between skyline server and client (cRIO)
Hi, guys.
Is there anyone who knows about the error code -251012 'Skyline configurations directory not found.'?
After I changed the server to another computer, It seems that cRIO-9067 can't recognize the server.
I already did set up Systemlink server on the new server computer and cRIO-9067 also are showed well on Managed Systems. However, when I run the code, skyline API in the cRIO make error -251012.
How can I solve this error?
(I am using Systemlink server 17.5 on server computer based windows OS and Systemlink client 17.5 on cRIO-9067.)
Message 1 of 8
(4,425 Views)
Accepted by topic author kreative_24h
You may want to double check your version. I bet you are using 17.2.
With 17.2 is you change your server you have to reboot you target to restart the LVRT service on the target since it caches the server connection information on startup.
With 17.5 it should automatically pick up the server change, but it won’t be released until next week.
Message 2 of 8
(4,418 Views)
Thanks, Joshua.
So, You mean.
If my systemlink version is under 17.5, I should reboot the RT target after my new systemlink server discovered and added it to the managed system list.
Right?
Additionally, I wonder what is the skyline configurations directory and when it will be created?
Message 3 of 8
(4,405 Views)
Yes, you should reboot your target when you change servers if you are using a version prior to 17.5.
Message 4 of 8
(4,401 Views)
Okay, Josua.
I resolved it.
But, Do you know what is the skyline configurations directory and when it will be created?
Message 5 of 8
(4,389 Views)
It is looking for the skyline_master.json file in the /etc/natinst/niskyline/SkylineConfigurations directory on the target.  The file is created after a system has been added to a SystemLink server and contains the routing information and credentials required for connecting to the server.
Message 6 of 8
(4,379 Views)
SystemLink 17.5 is now available in the NI Package Manager.  Please be sure to first upgrade the NI Package Manager to 17.5 before you try to upgrade the SystemLink Server or Client.
Message 7 of 8
(4,374 Views)
Thanks for your help.
I did upgrade both NI Package Manager and Systemlink 17.5.
Message 8 of 8
(4,366 Views)
