09-15-2020 08:27 AM
The DAQ station is running LabVIEW with IMAQdx for acquiring images from an IP camera.
To store and view Live video to the server computer, we are considering to use SystemLink.
Is possible to stream image over SystemLink?
Any Idea?
09-15-2020
01:50 PM
- last edited on
12-09-2025
12:24 PM
by
Content Cleaner
Our recommended approach is to use our File API. If the file is stored on the DAQ station after it is produced you can simply use the Send File VI to upload it to the SystemLink server managing the station. You may also stream a buffer the image data to the server without having to save it locally first.
09-15-2020 02:26 PM
As Mark mentioned if you need to store the data I would recommend using the File API.
In addition, here is an example I put together that shows how to transfer an image as a tag and then show it in the web interface using a WebVI. It isn't intended for live streaming, but it could be used to periodically see the latest image.
