SystemLink Forum
Create customized table in SystemLink server edition
Hello SystemLink forum,
is there a way how to create a customized table, where I can define my own columns and values inside a tile dashboard?
For example, I want to display temperature, voltage, etc. in a table.
The data itself is saved in tags on the SystemLink-Server.
Currently it's only possible to display test results or systems inside a table but I want to display my own data that's saved inside tags.
(214 Views)
You can customize it beyond what Grafana supports using Web Applications built using G Web Application software or regular Web tech stack.
Santhosh
Soliton Technologies
(210 Views)
Looks like you are using the basic tile-based dashboards (i.e. not Grafana) in SystemLink. Unfortunately they don't have a ton of configuration options. While it is a little bit more advance and currently not supported out of the box, you could try installing the optional Grafana support in SystemLink Server. The Grafana-based dashboards are much easier to customize and are what ship out of the box in SystemLink Enterprise for reference.
https://github.com/ni/grafana-plugins
This link should walk you through installing it, however you may want to start on a dev/test server at first until you are sure you like it before installing it on your production server.
(153 Views)
Thank you both for your reply.
I'm now using Grafana on my SystemLink-Server and was able to create dashboards as desired.
Before, I was only using the SystemLink basic dashboards.
Yes, I'm new to the forum and I will read the community guidelines and how to ask smart questions.
(129 Views)
