SystemLink Forum
Create a dashboard tile with a custom Jupyter Notebook
I am trying to work out how to display my custom Jupyter Notebook data in a newly created dashboard tile.
Following the OEE Health.ipynb example worked, however I was unable to link another Jupyter Notebook as a data source.
Choosing another data source only allows me to select the example OEE Health Notebook (see screenshot below).
(2,524 Views)
Thanks for the screenshot 😊
Two initial questions:
  • What version of SystemLink Server are you running?
  • Does this happen on a newly created dashboard?
RyanF
(2,487 Views)
Thank you for your prompt reply.
I am using SystemLink 2021 R1.
The dashboard was newly created but I also tried using an older dashboard.
I noticed that I could only include the "OEE Health.ipynb" as a data source. However, there are other notebooks in the same path (C:\ProgramData\National Instruments\Skyline\JupyterHub\notebooks\_shared\reports). Firstly, why are the other notebooks not visible, despite having the same path? Secondly, I would like to add my own notebooks as a data source, which are not preinstalled. Am I missing a mechanism to make the notebooks available as a data source?
(2,483 Views)
Do the other notebooks show up in the Reports page?
If so, can you check for the version of a notebooks that show up in one place vs the other?
In the Jupyter environment:
1. Upload the notebook
2. select the parameters cell
3. Select the gears in the top-right of the window
4. look for the version at the bottom of the JSON object in the cell metadata
(2,479 Views)
