SystemLink Forum
Connecting to Systemlink Cloud
I want to connect to SystemLink Cloud with LabVIEW 2015-2018 and SystemLink Client 18.0 combination,
but can not find how to do that.
Tags, that I'm creating using VIs from SystemLink palette, I can manage from SystemLink Server, but not from Cloud.
Where I can find any reference or documentation regarding this?
Ashkhen
(3,738 Views)
I believe you can't connect a SL client to a SL Cloud.
You can connect a LV application to SL Cloud tags. For this you first need to create an API key within SL Cloud. This key can then be used together with the Skyline configuration->Open Configuration API key polymorphic instance, which has an API key input.
There is a draft white paper discussing this "NI-s-Web-Security-unreleased-white-paper", although you need acces to the NI Web Technology Lead User Group to view it.
André (CLA, CLED)
(3,734 Views)
Accepted by Ashkhen
Hi Ashkhen,
Most of our SystemLink Cloud is at systemlinkcloud.com including information about the Skyline API and an FAQ. One key difference from using SystemLink Server and SystemLink Cloud detailed in the FAQ is the use of an API key. I would focus on using that information in this application!
Best,
Chris D. | Applications Engineer | National Instruments
(3,704 Views)
