SystemLink Forum
Are 'Batch serial number' and 'Test Socket Index' available via API
Hi All,
I would like to use the data fields 'Batch Serial Number' and 'Test Socket Index' from the Test data table. In the HTTP API they are not described, is it possible to use them anyway?
Kind regards,
Coert Ansems
(4,073 Views)
Yes you can. Those are displayed when a specific reserved property has a value. You should be able to add the property to the Test Result when you upload it using the HTTP API and it will be displayed in the Test Module's GUI. I've included the two properties below and included a screenshot showing the properties on an example test.
  • Batch Serial Number - Prop Name: "nitmBatchSerialNumber"
  • Test Socket Index - Prop Name: "nitmTestSocketIndex"
Brandon Grey
Certified LabVIEW Architect
(4,053 Views)
Hi Brandon,
Thank you for your reply. Is there any documentation on these reserved properties or do you have a list of these reserved properties?
Kind regards,
Coert Ansems
(4,037 Views)
Unfortunately we don't have documentation for those tags yet. We hope to add that documentation in future releases.
Brandon Grey
(4,031 Views)
is it possible that you can just share the list with very short notes on each in this thread then, so we can see what's available? Or does your picture actually show all reserved tags?
CLA, Teststand and advanced SQL
(3,881 Views)
