Switch Hardware and Software
PXI 2576 - Can all the switches be turned ON simultaneously
Can all (or multiple) switches in one bank be turned on simultaneously? As shown below
(6,727 Views)
<Edited Response - See Post Below>
Mike Watts
Product Manager - Modular Instruments
(6,717 Views)
Thanks!
I was trying to find a solution with our existing hardware.
I am trying to do an automatic open/short test on an IC and need to cycle through the 48 pins one by one, while the other 47 pins are connected to GND.
(6,710 Views)
Accepted by topic author vikasg
After talking with a few colleagues, I was reminded that there is a way to make it work with your existing hardware. If you use the NI-SWITCH driver, there are a set of individual relay control functions that will allow you to connect multiple inputs within the same multiplexer. However, this method will have a more complex code implementation, since you will need to control each individual relay manually. Here is an example that uses a for loop to close every relay on the 2576.
Sorry for the confusion!
Mike Watts
(6,703 Views)
This is perfect! Thank you so much Mike!
(6,698 Views)
