Switch Hardware and Software
PXI-2575 pin description in 196x1 multiplexer mode
I want to use this switch as a 196x1 multiplexer. Where can I find the pin description for the connector.
(6,893 Views)
Hi BartvStC,
I've attached the pinout for the PXI-2575 front connector when the module is configured in its 1-Wire 196×1 Multiplexer Topology.  You can find the same pinout in the NI Switches Help.  If you are at all interested in the pinouts when using the LFH200 cable accessories, then you can find them in the LFH200 Cable Installation Instructions.
Let me know if you have further questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
(6,891 Views)
