Switch Hardware and Software
How can I do fault injection with CANoe?
How can I do fault injection using Vector's CANoe application?  CANoe supports devices that use the DAQmx driver, so if there is something that uses the DAQmx driver that could do that it would be nice because I also do need to do some data acquisition and the fewer pieces of equipment required the better.
(8,112 Views)
Hi jnclaker-
     I will refer you to this DeveloperZone tutorial as I think it may answer your questions.  It refers to our Fault Insertion Product line, which I think is what you are looking for.
     I hope this helps.  Have a great day!
Gary P.
Applications Engineer
(8,106 Views)
Take a look at the PXI-2510 Fault Insertion Module, which is supported in the DAQmx driver.
-John Sullivan
Problem Solver
(8,100 Views)
Do you have any USB devices?  I would rather not tie up a PXI chassis with something that is not deterministic because CANoe runs on Windows.
(8,096 Views)
