Switch Hardware and Software
取消
显示结果
搜索替代
您的意思是:
Error -1074118124
I'm getting "An error occurred while performing the switch operation 'Connect' for the following device 'VirtualDevice1'.
Could not perform the switching operation:
Details:An error has occurred while attempting to access device sw
Agilent34980A: IO error: .(Error = -1074118124)" while trying to switch a route from Teststand.
I am using Teststand 4.2 and NISE 3.0
I also want to mention that Switch configuration validation is Pass and if I use TestPanel it works. It doesn't work only from Teststand.
Please help,
crsz
0 项奖励
1 条消息(共 11 条)
9,090 次查看
It appears you are making Switch Executive calls, but can you please explain how you are calling the switch functions in Test Stand (ie. LabVIEW calls, etc.).  Also ,can you run a NI Spy capture to see what VISA commands are sent out and the errors returned as well when you run the Test Stand code.
It could be that the Agilent Switch does not like the calls that are being made.  How is the Agilent Switch connected to your controlling PC (GPIB, USB, etc)?  Can you try to make the switch calls using LabVIEW calls (if this is an option for you)?
Best,
Adam
Academic Product Manager
National Intruments
0 项奖励
2 条消息(共 11 条)
9,059 次查看
Thank you for replying,
I make the switch calls using Teststand Switching panel (Step properties)
It works from Labview (switch_executive_getting_started.vi) and Switch Executive API
Route Validation is Pass (in MAX) and it works from MAX - Switch Executive Test Panel
I am using a GPIB-HS USB interface and Windows 7
I will post ASAP NI Spy capture - if I remember correctly it fails only at the step nise(switch....)
Cristian
0 项奖励
3 条消息(共 11 条)
9,052 次查看
And NI Spy capture...
0 项奖励
4 条消息(共 11 条)
9,046 次查看
Hi crsz,
Thank you for the reply.  This has been documented before encountered with Agilent switches when using the GPIB interface with SwitchExec Calls in TestStand.  Can you connect your device via USB to your host machine, or serial?  This has been known to be a workaround, and is worth a shot.
See this post as well: http://forums.ni.com/ni/board/message?board.id=320&message.id=1006&requireLogin=False
Best,
Adam
National Intruments
0 项奖励
5 条消息(共 11 条)
9,034 次查看
Hi crsz,
Another follow-up question.  Can you validate that the switch is able to work with the driver listed here: http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1628832&nid=-34438.779160.02&id...
Best,
Adam
National Intruments
0 项奖励
6 条消息(共 11 条)
9,003 次查看
Hello Adam,
Sorry for my late reply, I had a few days off...
I will try it with the this drivers, but aren't they labview drivers? I intend to use IVI drivers...
Cristian Szabo
0 项奖励
7 条消息(共 11 条)
8,968 次查看
Indeed they are LabVIEW drivers.  Can you provide a link to the IVI driver you are using?  Further, can you try to use your device via USB or serial?
Best,
Adam
National Intruments
0 项奖励
8 条消息(共 11 条)
8,955 次查看
Hello Adam,
I have tried it connecting 34980A directly to USB and it's working indeed.
Currently I am using IVI-COM, IVI-C Version 1.4.2.0 for 34980A because in my configuration I have a 34939A not supported by previous drivers. I have also tried  IVI-COM, IVI-C Version 1.3.10.0 for 34980A for NI Switch Executive but it was still not working.
Important thing is that when connecting 34980A directly to USB it works!
Another question - hope it is ok to ask in this post - not necessarily related to this error but related to 34980A IVI drivers. In my configuration I have a 34921A MUX card in slot 1. Why can't I see Channels "1043" and "1044" (in switch executive) for current measurements and why do I have "slot1com3" channel for this 34921A ? Channels "1041" and "1042" do exist though...
Driver setup is: dmm=true, slot1=34921A-2W, slot2=34932A, slot3=34939A
Thank you and regards,
Cristian
0 项奖励
9 条消息(共 11 条)
8,949 次查看
Hi Cristian,
Let's proceed by filing this question in a new post.  This will help to better document the threads for future reference.
Best,
Adam
National Intruments
0 项奖励
10 条消息(共 11 条)
8,939 次查看
