Hello Community,
I've developed a LabVIEW based tutorial utilising the myDAQ to explain some of the concepts of what is called two-port network theory.
The tutorial takes you through:
The application is only provided as a compiled exe due to some of the existing NI IP re-used within the program. You should be able to run it with the standard LabVIEW Run Time / Dev Environment, DAQmx/MAX and NI-ELVISmx installed, but if there are any issues let me know.
I hope people find this interesting, especially if it is a new conecpt to you, as it is a very powerful way of modelling circuits from a high-level. Thanks for taking a look!
