Our project proposes the usage of Anti-theft control system for Drinking water supply. By implementing our project in a real time, surely we will be able to control the drinking water theft in the domestic areas. In this system a “Water flow sensor” and a Solenoid valve is directly connected in the pipe line of water supply. The sensor operates under certain predefined value. When there is a variation in the water flow due to any pumping of water through motor, it will be detected by the water flow sensor. The analog signals generated due to variation in the flow of water sensed by the water flow sensor are converted into digital signals using Analog to Digital Convertor (ADC) and this digital signal is given to Microcontroller. This microcontroller enables the RF transmitter for intimate to water supply board. At the same time they enable the driver unit to closes the solenoid valve. We can create a simulation of this project using the LAB VIEW platform.
