Sensor Type: DHT11, RHT11 - Temperature & Humidity Sensor
LabVIEW or C: LabVIEW
Version of LV: 2013
Description:
DHT11 is a composite sensor contains a calibrated digital signal output of the temperature and humidity.
DHT11 sensor uses a single-wire bi-directional protocol.
Download DHT11 datasheet from web for more information and specifications.
Instructions:
The API is implemented on FPGA.
To get the measured temperature and humidity values from DHT11 use 'DHT11 Read (FPGA).vi' in API folder from 'DHT11 (FPGA).lvlib.
There is also 'Example - DHT11 (FPGA).vi' in Example folder. The 'Example - DHT11 (FPGA).vi' must be compiled in order to be used from the FPGA Interface.
Wiring Diagram:
