The NI ELVISmx DC Level is an instrument that generates a DC voltage from the analog output channel. You can set the voltage control to vary the voltage from +10 volts between -10 volts.
Make sure your signal output terminal matches the Channel Setting Control. For further connection information, refer to your hardware reference manual.
Complete the following steps to output a voltage with the NI ELVISmx DC Level instrument:
Cant get this to download. I tried to download it, and when I tried to run it my computer asked me to chose a program to run it. can anyone help me.
Do you have LabVIEW installed, it should be version 10 or higher.
If you do have LabVIEW installed, try to open the file manually. In LabVIEW select File>>open, navigate to your download folder and open the file.
If you can open the file manually, then you have a file assoication problem. Have a look at the following knowledge base for fix this.
https://support.microsoft.com/en-us/help/18539/windows-7-change-default-programs
