South East Michigan LabVIEW User Group
Introduction to Source Code Control using TortoiseSVN
Introduction to Source Code Control TortoiseSVN presented at the SEMLUG meeting Nov 5, 2009
Dan Shangraw, P.E.
(9,611 Views)
I found this in the TortoiseSVN Book regarding using the Copy/Merge vs. Lock/Unlock
Here is a great article on how to merge VI's in subversion.
Subversion generally works best without locking, using the “Copy-Modify-Merge” methods described
earlier in Section 2.2.3, “The Copy-Modify-Merge Solution”. However there are a few instances when
you may need to implement some form of locking policy.
• You are using “unmergeable” files, for example, graphics files. If two people change the same file,
merging is not possible, so one of you will lose their changes.
• Your company has always used a  locking  revision control system  in  the past and  there has been a
management decision that “locking is best”
Dan Shangraw, P.E.
(3,566 Views)
