The attached code demonstrates the implementation of Spectrally Efficient Frequency Division Multiplexing (SEFDM) transceiver system.
This work introduces a world-first, experimental, real-time implementation of baseband generation, signal assembly, signal decoding, and a novel frequency domain channel estimation and equalization method.
Download the code below and open "Turbo_SEFDM-Tx and Rx Streaming Time (Host)_WOzan.gvi"
LabVIEW Communications System Design Suite ver. 2.0 (Free evaluation)
USRP-2953
hello Mr.
I went through your example program as I am using NI USRP 2944 160 Mhz but i noted that there is many warnings in the program but its able to run , once i run the program i didn't got any good constellation diagram as per attached , so any advice from your side .
Hello Romaro,
Do you get a good constellation with OFDM modulation?
Waseem
