Software Defined Radio
Implementation of the SEFDM 5G Transceiver
Overview
The attached code demonstrates the implementation of Spectrally Efficient Frequency Division Multiplexing (SEFDM) transceiver system.
Description
 The case study details the challenges and solution that the team worked on.
http://sine.ni.com/cs/app/doc/p/id/cs-17492
This work introduces a world-first, experimental, real-time implementation of baseband generation, signal assembly, signal decoding, and a novel frequency domain channel estimation and equalization method.
Download the code below and open "Turbo_SEFDM-Tx and Rx Streaming Time (Host)_WOzan.gvi"
Hardware and Software Requirements
LabVIEW Communications System Design Suite ver. 2.0 (Free evaluation)
USRP-2953
Comments
Romaro
on
hello Mr.
I went through your example program as I am using NI USRP 2944 160 Mhz but i noted that there is many warnings in the program but its able to run , once i run the program i didn't got any good constellation diagram as per attached , so any advice from your side .
5G Researcher
Waseem90
on
Hello Romaro,
Do you get a good constellation with OFDM modulation?
Waseem
Contributors
