SignalExpress
signalexpress duration of process
I would like to learn that how many seconds does the program need to generate at a given number of iterations?
For my experiment, I need 6200 pulses.  Whether I arrange the frequecy to 750Hz ( Sample Rate = 750k S/s, Block size= 1000), I need to arrange the number of  iteration as 6200. But if I arrange the frequency to 15k Hz ( same sample rate and block size ), number of iteration  becomes 155, for 75kHz, number of iteration is 31.
However, I do not know what kind of relation is avaible between the time to generate 6200 pulses and current frequencies? I mean I would like learn that
for 75k Hz to generate 31 iteration, how many secs does it need?
And is it linear for all frequencies?
Thank you,
SA
Message Edited by Emraisel on 05-25-2010 04:53 AM
(5,761 Views)
Could you produce some kind of timing diagram so we can get a better understanding of what you are trying to do?
(5,722 Views)
