SignalExpress
pulse width conditioning
I have a square wave/pulse train (1d array). I want to reduce the pulse width. Please see the figure. Here, the green line shows the falling edge of the reduced pulse I want to create from the longer width pulse. Pleae suggest a solution
(5,599 Views)
We need more information.  How are you generating the pulse stream (LabVIEW function, SignalExpress step)?  Virtually all National Instruments products which produce square waves (hardware and software) give you a duty cycle option.  Reduce the duty cycle percentage and you should be there.
(5,593 Views)
