SignalExpress
initialization error
I have Labview 8.5 (full) installed on windows XP.  When I try to run Signal Express (ver 2.5), I see the splash screen, then an error pops up "Initialization error.  Could not start the program.  Contact National Instruments"
Any idea what this is?  I already tried reinstalling Signal Express thru Windows (Add/Remove Programs)
Ron
(7,205 Views)
Hi Ron,
I was wondering if LabVIEW SignalExpress has worked before and if this error has is something that just started recently. Also, what version of DAQmx are you using? Any additional information you can give you be helpful.
Kent
(7,190 Views)
Kent,
This is the first time that I've tried Signal Express, on a LabView install that I've been using for the last year or so.  It is licensed for the limited edition according to the license manager.  DAQmx is now 4.4.1f0-- just updated, but that didn't help either.
Ron
(7,180 Views)
Hi Ron,
This issue may be best diagnosed by talking directly.
If you give us permission I can check your contact info on the Discussion Forum and contact you directly or if you are comfortable you can  just post a way for me to get in touch with you.
Kent
(7,163 Views)
