SignalExpress
cepstrum
sir , I dont have the LABVIEW advanced toolkit for cepstrum analysis. As said by the defenition of cepstrum, is it possible to have cepstrum analysis, with out installing the advanced toolkit.I want to try it as follows 1.First take FFT (power spectrum) 2. Then take logaritham(base 10) 3. then take Inverse fourier transform , then we get cepstum Thank you .
(5,908 Views)
You accidentally posted under the SignalExpress forum, not the LabVIEW forum, so you might want to repost there is you do not get a good response here.
To answer your original question, the Full and Pro versions of LabVIEW have built-in functions for FFT, logarithm, and inverse FFT, so doing it your self should be fairly easy.  If you have the Base version of LabVIEW, you will need to write the FFT and inverse FFT yourself.  LabVIEW is a fairly complete general purpose programming language with an enormous number of built in functions, so none of this should be difficult.  Many years ago, long before I joined National Instruments, I used to prototype algorithms using Mathematica, then translate them to LabVIEW for "real-time" use.  I never had any trouble doing it.
Good luck.  Let us know if you need more help.
(5,907 Views)
Sir,
Thank you for your support.
Bibi
(5,903 Views)
