SignalExpress
analyze functions
I have used SE previously to do some signal processing while logging.  In SE 3.0 these functions seemed to have disappeared.  Is that true.  When ever I try to load the example of thermistor logging/alarms it crashes the system.  Please advise.
Chuck
(6,353 Views)
That particular example has been removed in SE 3.0. I am looking into why this was done.
(6,343 Views)
The example has been replaced by Logging Simulated Temperature with Alarm. You can find this in the folder Examples\Data Logging. You should still be able to process data while logging it as well.
(6,318 Views)
