SignalExpress
acquire data from two channels signalexpress
Hello
Right now, I am able to acquire the signal from a single channel and display it.But I would like to know of how to acquire signals from two channel cells simultaneously.I am using signalexpress and using NI USB-9162 with AI config to acquire the waveform.It would be of great help if you could suggest a simple method to acquire the signals.
 PS: Please find the attached file used for acquisition from a single load cell. Looking forward for your reply.
SA
(6,061 Views)
Hi SA,
Provided you want the second channel to acquire at the same rate as the one you currently acquiring, you can add another channel by clicking the blue "+" in the Channel Settings on the Configuration tab.
Jas.W
Jason W.
National Instruments UK & Ireland
(6,014 Views)
You should note that if you are using multiple signals from the same device in DIFFERENT STEPS, you have to use a Sequence step in a certain way.
SignalExpress 2009 comes with an example:
Go to Help – Open Example – DAQmx -
Hardware Reuse with Sequence Step.seproj
(5,982 Views)
