SignalExpress
What is Signal Express' slowest supported sample rate?
I'd like to monitor some temperature vs. load trends over the weekend and really only need one sample every 5 min or so.
Will Signal Express handle that (without using the logging function; just Save to Ascii)? According to my calculation that's like 0.003333333hz. Does that sound right? or is this the wrong approach.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,781 Views)
Hello OKors,
I have been successful in using One Sample (On Demand) with a sample period of 5 minutes (300 seconds).  This will be software timed, but it does not sound like you need the measurement to be precise to the nearest microsecond (hardware timed), and that a little software jitter (millisecond range) would not be an issue. You can then add the step to save the file to ASCII.
Best,
Adam
Academic Product Manager
National Intruments
(5,763 Views)
