SignalExpress
What are the units for the power spectrum output? (units in)^2/Hz?
I can't seem to find the answer in the manual that came with the software or anywhere online.  Maybe I am just looking in the wrong places.
David
(5,757 Views)
Hi David,
I assume you are referring to the step, "Power Spectrum", in Analysis»Frequency Domain Measurements
Per the help that I see, "This step can return the spectra in root-mean-square, peak, and peak-to-peak units."
Also, in the configuration tab of the step, for magnitude you can select either dB or linear.
Hope that helps!
-Sam F, DAQ Marketing Manager
(5,747 Views)
