SignalExpress
Using 'Chart' option for data logging in SignalExpress 3.0
I am trying to view streaming data in a chart format with SignalExpress 3.0.  Presently, the 'Chart' option is greyed out and I can't figure out what I need to do to make it an option.
(6,204 Views)
Hi dhallida,
You can only select the Chart as an option when you have your acquisition mode set to "1 Sample (On Demand)".
Stephen Meserve
(6,194 Views)
I may be missing something since I'm pretty new at this myself, but I'm able to view incoming data in a chart (sweep, scope, etc) without being in 1 Sample (On Demand) mode.
I have to add an Amplitude and Levels step then drag the signal from within that step into the graph. Then right click the graph>Update Mode... chart options.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(6,167 Views)
